A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
bluescreen of memory management
my pc gets memory management error out of nowhere and reboots several times when i open many apps or gets booted bhen playing games or doing any of the work
  1. Check memory seating inside PC , in the slots
  2. Run ram check
  3. Test with diffrent good known ram & re-run ram check (if bad > )
  4. clean slot or cpu pins
  5. If it works with new ram , clean the old ram golden pins with eraser &/or contact cleaner + a brush
  6. Re-test.
  7. Update bios , set manually ram timings & voltage to ram maker specs ,
  8. Check motherboard compatibility with problematic ram on mb maker home-page. (if it's not in the QVL list it may not work properly so test your ram on diffrent system.)
Yasir Arfat crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 183
