Threaded insert came out of the front plate
Now there is a gap between the back and front plates of my OG ROG Ally. Is there a way to attach the threaded insert back in place?
Looks like you have to take a screwdriver kit and open the case, then reattach your part. Do not try to force push the fallen part back, you can damage something. Also opening the case will void the warranty.
@kapitalizm But how to reattach it is my question.
I’m here thinking I have to put superglue around the insert before putting it back in, but I’m not sure there is a different method or kind of adhesive more adequate for this, which is why I’m here.
It is a given that I’ll have to open the back, and this is my third year with the device, so no warranty to worry about even tho I don’t think opening it kills the warranty.
@moody61930 if there's no way to attach it (usually there must be screws or plastic latches) try to not use superglue, if part must be glued, use B7000 instead, because it can be removed if needed. Superglue (cyanoacrylate) should not be used, cause it comes in chemical reaction with a plastic and sometimes even melting it, so your parts will be damaged completely.
