Released in June 2019, the Valve Index comes either in a full kit with the Index Headset, Index Controllers, and Index Lighthouses, or as separate components.
Right side speaker cutting out periodicially, no obvious cause
My Index's right speaker is frequently cutting out during use, especially if I pull the headset off my face to adjust it or apply any pressure to the bottom right of the headset, which is making me think its something internal that's causing it. So far I've tried these solutions:
  • cleaning the contacts with alcohol
  • replacing the speaker entirely
  • using a different trident cable
  • putting an o-ring around the mounting point
I've had no success. I can't find any breakdowns of the mobo that might detail where the speakers connect up to it, so I'm nervous to go rooting around there without knowing what I'm looking for. The unit was bought refurbished over a year ago, so I don't have a warranty to claim unfortunately.
Any ideas?
Ideas are simple, you have to teardown the head part and check everything speaker-related connections. If it'll lead you to the sound IC that not producing signal (it can be amplifier, pre-amplifier IC, adc or MCU), then you have to search for a replacement (not sure if there's a replacement for all parts, so that's a bit of luck)
For diagnose you can enable sound generator on the input and use an oscilloscope.
Aiareck crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 36
