Leaking water at bottom front right corner
What is the source of this leak, and can it be repaired?
You have to teardown the case. The source of the leak can be blown gasket or plastic part. Sometimes it can be fixed with applying a silicone gasket to the leaking part (not the corner cause in that case water will destroy inner components)
Ok, will proceed as suggested. Thank you!
crwdns2942667:0crwdne2942667:0 85
