Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
Why is my laptop not turning on?
Laptop Model: HP EliteBook 840 G3 (Energy Star)
OS: Windows 10
SSD: 256GB NVMe
RAM: 16GB
Issue Summary
After a recent Windows 10 update (auto-installed overnight on 10/09/2025), my laptop no longer boots properly.
When I press the power button:
  • Power button, keyboard backlight, and Caps Lock light all turn on.
  • The HP logo briefly appears on screen.
  • After that, the laptop powers off by itself.
  • This repeats in a power-on / power-off loop.
Troubleshooting Attempts
  1. Power drain reset – Held the power button for 30 seconds to discharge. No change.
  2. Battery removed – Tried running only on the adapter cable. Result:
    • Power and Caps Lock blink once, then system shuts off, looping again.
  3. CMOS reset – Removed and reinserted the CMOS battery. No effect.
  4. RAM reseating – Swapped RAM modules into different ports. Problem persists.
  5. BIOS recovery attempt – I already have the correct BIOS flashed onto a USB drive, but the system doesn’t stay on long enough to start recovery due to the boot loop.
  6. Pending test – Planning to test with a different RAM stick to rule out memory failure.
Current Situation
  • Laptop is stuck in a boot loop, unable to load BIOS recovery or Windows.
  • Only remaining suspected causes: RAM issue, motherboard fault, or BIOS corruption.
Anyone with the same issue and successfully fixed theirs?
What your symptoms suggest
  1. It powers on, lights flash, HP logo shows briefly, then power-off loop
    Not a dead motherboard (since you get the logo), but the handoff between firmware → POST → OS is failing.
  2. Caps Lock flashes once
    On HP laptops, blink codes matter. A single Caps Lock blink is usually CPU not functional or BIOS corruption, but since it gets to the logo, CPU is probably fine. This points more toward firmware/BIOS corruption.
  3. Windows update before issue
    Sometimes HP BIOS auto-updates via Windows Update (yes, really). If it failed or glitched, it leaves the system in exactly this loop.
✅ What you can try next
1. Force BIOS recovery the “HP way”
  • Plug in AC adapter.
  • Hold Windows + B keys, then press and hold the Power button for ~3–5 seconds.
  • Keep holding Windows + B until the screen lights up or you hear beeps.
  • This forces the system into HP BIOS recovery mode from USB or internal recovery partition.
  • Since you already prepped a USB with the BIOS, this is the method most likely to get it working.
(If Win+B doesn’t work, try Win+V instead — some EliteBooks use that combo.)
2. External monitor test
  • Just to rule out a display crash (rare but possible).
  • Connect HDMI or DisplayPort monitor, see if it shows more info before shutdown.
3. Test one RAM stick at a time
  • You mentioned you’ll try this — good call.
  • Boot loops with a quick logo flash often happen when RAM partially works (detected but failing during POST).
  • If you’ve got spare DDR4 SODIMM, even better for cross-test.
4. Reflash BIOS externally (last resort)
If BIOS recovery doesn’t kick in:
  • You’d need an external programmer (e.g., CH341A clip) to reflash the BIOS chip directly.
  • This is usually the fix if the system bricks after a Windows-pushed BIOS update.
  • Not DIY for most, but repair shops can do it quickly.
I tried on a new Ram stick. Still had the same issue.
I still can't boot in into bios
The display has a little backlight when turning on so there isn't a display issue
The fan doesn't turn on at all
I may have to say, it is a motherboard problem
Ben Mugo Esq. crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 50
