Getting unstable readings from GP2Y1014AU0F dust sensor
Hi everyone,
I recently picked up a GP2Y1014AU0F PM2.5 optical dust sensor module to use in a DIY indoor air quality monitor. The idea is to track fine particles and log values with an Arduino for later analysis.
Setup Details:
- Arduino Uno
- Sensor powered from 5V pin
- Vout connected to A0 for analog reading
- 150Ω resistor on the LED pin as recommended in schematics
- Simple sketch averaging multiple analog reads to smooth out the signal
Now here are my issues:
- The readings fluctuate a lot, even when the room is stable (values jump up and down constantly)
- Occasionally, I see huge spikes in the output that don’t make sense (like 5–10× higher than normal)
- I’m not 100% sure if I wired the LED/V-LED pins correctly — the datasheet instructions feel a little confusing
- Averaging in code helps a bit, but the data still looks too noisy to be useful
What I’ve tried so far:
- Checked my wiring twice, seems okay
- Added delays in the loop to slow down reads
- Tried powering from a separate USB power bank to see if it was a supply issue
My questions:
- Is this level of noise typical for the GP2Y1014AU0F, or should it be more stable?
- Would adding a capacitor near the sensor help reduce voltage fluctuations?
- How do you properly calibrate this sensor to get PM2.5 values in µg/m³ from the voltage output?
- Any placement tips (near air vents vs still air) to get more realistic readings?
Thanks in advance for any suggestions.
crwdns2889612:0crwdne2889612:0
0
