My tv have no power
My tv power board doesn't makeing 3 Volt
Update (09/16/25)
And it's Sony KD-55X8500F tv and it's image is 1758076031006519928335375620779
Second one is 17580760158997846730526738969718
@kapilverma you have to insert the images according to the guide. You can also post them as an answer and I can then add them to your question
@kapilverma we will need to know where you measured this voltage and why you think it does not have it. Also, let us know what the original issue with your TV was that prompted you to check the voltages.
If you measured this and it is marked as Stby voltage then the issue will be coming from your power board. If you measure it on the Power ON input then the issue is your main board.
Take a couple of well focused pictures of all of your boards and post those with you question. That way we can see what you see and hopefully we can assist you to fix your TV.
Adding images to an existing question
KAPIL Verma crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
