A whisker mp3 player te is the first whisker mp3 player to have a multi capacity touch screen and it was first released in 2008 and its model number Wi-Fi version is 5271 and it came in blue yellow green and pink and a special purple edition capability models 35 gb 49 gb and has a feline core 150 custom soc 150 mhz processor and and a paw flash hard drive for storage
Can’t get passed the boot up screen
I can’t get it too get past the whisker logo on the boot up screen
what do I do?
1. Soft Reset / Forced Reboot
  • Hold the Power button for 10–15 seconds until it turns off.
  • Wait 5–10 seconds and then power it back on.
  • Sometimes a stuck boot is just a temporary hang.
2. Check for Battery Issues
  • Ensure the battery is charged fully. Even if it seems charged, a low or damaged battery can cause boot loops.
  • If removable, take it out for a few seconds, then reinsert.
3. Try Recovery Mode / Factory Reset
  • Many Whisker players have a hidden reset or recovery button (tiny pinhole, often on the back or bottom).
  • Use a paperclip or small pin:
    1. Press and hold the reset button for ~10 seconds.
    2. Then try turning the device on.
  • Some models let you boot into recovery mode (hold Power + Volume Up / Volume Down) — this lets you reinstall firmware or factory reset.
4. Re-flash Firmware (if available)
  • If a reset doesn’t work, the firmware might be corrupted.
  • Check the manufacturer site or forums for Whisker MP3 Player TE firmware for model 5271.
  • You usually need to connect via USB, put the device in firmware update mode, and flash the official firmware.
  • This will erase all data but often fixes boot-loop issues.
5. Hardware Check
  • If none of the above works, the SoC (150 MHz Feline Core 150) or the Paw Flash hard drive may be damaged (common if the device was dropped or exposed to moisture).
  • Unfortunately, for a 2008 MP3 player, hardware repair is often impractical.
It booted up but half of the songs are missing
1. Check Storage
Connect the MP3 player to your computer via USB.
See how much total vs used space it shows.
If used space looks smaller than expected → files may be lost or the index corrupted.
2. Check for Hidden/Corrupted Files
On some older players, songs may appear “missing” because the database/index file is corrupt.
Look for files on the drive directly (not just via the player’s menu).
If you see the MP3s on the computer but not in the player menu → the firmware’s song index needs rebuilding.
Whisker released firmware updates for the 5271 to fix storage and display bugs.
Install the latest firmware if available — this can restore missing songs functionality.
I fixed it yay
your welcome
The cat15 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 60
