Repair guides and support for Android phones manufactured by HMD, including feature phones and smartphones with Nokia and HMD brands.
Broken Micro USB Port on Nokia 800 Tough
I own a Nokia 800 Tough which has a broken micro USB port. On the broken one is a lettering saying "17M1D V2", but I can't find one using this model / whatever number on the internet. Any help would be really helpful!
@oldturkey03 Thanks for your quick reply!! Actually, this phone was already broken as I bought it (second hand) and I wanted a challenge. If the charging connector you linked is actually like in the picture, I doubt it will fit (as it's upside down; pins are on the "wrong" side). But maybe I could give that a try (as I live in Germany I am curious if shipment will work). Sadly, contact via WhatsApp doesn't seem to work: I tried it and WhatsApp said the number is unknown.
But when I find the time, I'll be trying to first re-solder the port and see whether it works again! If not, I'll post my findings here!
@redlux this ""17M1D V2" is most likely just a manufacturers number, not a part number. You would need to measure the port (total dimensions and the pin pitch (pin to pin). Now you would take those dimensions and try to match the connector. You can always check places like mouser.com or digikey.com and see if you can find a match. This is long and tedious work. Sometimes it is better to find a broken phone/board at places like ebay or similar and use that as a donor board for your phone.
Every now and then we even have to risk dealing with companies that nobody knows anything about. Something like this Contact them and see what they tell you:-)
Redlux crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 42
