Repair, disassembly, and troubleshooting information for Apple's "smaller" 2023 flagship smartphone, released September 22nd. It features a 6.1" ProMotion OLED display, a triple-lens rear camera system, and 5G. Successor to the iPhone 14 Pro.
Screen provided looks different to old one?
The screen size is the same but has metal slots on back of the new screen but not on the old one. I have tried to fit but there is no slots in the phone to take the metal slots. Am I doing something wrong like removing the metal back of the new screen. It is also a lot thicker than the original broken screen? Ha e they sent me the wrong one or is it my mistake?
Hi! It’s hard to say without photos.. could you make some photos and post it here?
Guide: Adding images to an existing question
Thanks!
We've been seeing this more and more with the later model iPhones such as yours. What's happened is that the screen's mounting frame has come off the screen and is still on the phone. It seems the adhesive Apple uses to secure the frame to the screen isn't nearly as good as it used to be, making it much easier to get between the screen frame and the screen rather than the screen frame and the phone.
All. you need to do is go around that screen frame again, repeating your opening procedure and remove the frame from the phone. It should be easier than initially removing the screen, as you can get under the frame from inside the phone and pry it up.
Lay your new screen side by side with the original and you'll see the difference between them is your old one is missing the frame around it. Now look at the phone; there's the frame. Go ahead and remove it, then you can continue with your replacement.
Thank you so much for your reply.
And the lag is that changeable in the settings?
@benjamincur4499 What lag are you referring to?
Benjamin Curtis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 43
