Touch stops responding and only responds to long press
When I use my phone it stops to respond to my touch and only work if off and on . And I have to constantly touch my phone to make it respond to one command like touch 2 second and swipe without removing finger out of display 😭 it's annoying
First thing is to try booting into Safe Mode. This will disable any apps that could be interfering with the touch screen. Power off the phone, then follow the instructions from the Xiaomi help page.
Safe Mode FAQ
1. Q: How to turn on safe mode on the phone?
A: When the phone is turned on, long press the volume down key to enter the safe mode. After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen.
If that works, the problem is with one of your apps. You'll need to delete any apps you've installed, one at a time until you find the one that's causing the problem.
If the issue is still there in Safe Mode, it's likely your digitizer (touch screen) has failed and you'll have to replace the screen to fix the problem. Here's a guide giving you instructions on how to do that.
Xiaomi redmi 12c screen replacement and disassembly using original display - YouTube
I just did the factory reset but still not fixed so might that be my hardware problem??
@rohitkhana77699 By far the most likely cause at this point is a failed digitizer, so a screen replacement is what I would do if it was my phone.
But my display not cracked
There are several ways a touch screen can fail, so the glass being undamaged doesn't mean the digitizer is still working.
Rohit Khanal crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 115
