Repair and information guide for the GE Refrigerator GFE26GMH****—a French Door style refrigerator with bottom-mounted freezer, automatic ice maker, and through-the-door service feature, introduced in 2014. This page covers information for model numbers matching the pattern GFE26GMH****.
Fluctuating refrigerator and freezer temps
Picked up a non-working GE French door, freezer on the bottom frig - mode GFE26GMHEES. I replaced the upper and lower interior fans, and appears to be working as it should. Was going to run it for a week, before I put anything in it. Freezer is consistently -5 to -8 and refrigerator portion is around 32-35 degrees when I have checked it. However I have caught it twice when the refrigerator shelves were kind of fogged up, and temp was higher and closer to 50 (condenser fan not running). If I go back 30 min, condenser fan is running and it is back down to the -5 and 32 degree temps. Since I didn't own when it was working, but sure if this normal, and I am catching in a defrost cycle or something like that? Or do I have an intermittent issue?
Hi @js2318
Seems though it is normal as the refrigerator might be in its auto defrost cycle.
Best that I can find out is that it uses the adaptive defrost method.
This means that the defrost cycle only occurs when it is deemed necessary. The logic on the control board uses such factors as ambient temperature, number of times the doors have been opened and how often and for how long the compressor has been operating to determine when a defrost cycle is necessary, so it could occur once anywhere between 8-30 hours
The defrost cycle usually lasts about 20-25 minutes. During the defrost cycle, the compressor and evaporator fans are both turned off and the defrost heater under the evaporator unit (behind a panel in the freezer compartment) is turned on to melt any ice that has built up on the evaporator unit. The meltwater from the ice drains out through a drain tube to an evaporator pan under the refrigerator compartments (near the compressor) to be evaporated naturally.
At the end of the defrost cycle, the heater is turned off (or is turned off sooner as the temperature near the evaporator is monitored by a defrost bi metal thermostat to prevent damage to the evap unit in case it gets too hot) and the compressor and evaporator fan are both turned on again to drive the temps back down again to their set operating temperatures.
Of concern is the fogged up shelves. This could be an indication that warmer outside humid air is entering the compartment when it shouldn't be and starting to condense.
Try placing a turned on flashlight inside the refrigerator compartment and with the door closed normally i.e. no pressure on it by you to keep it closed, check if you can see any light escaping through the door seals. Check all around the door, top, bottom and both sides. Probably best done at night when it is dark as it will be easier to see if there is any light shining through.
If there is check the door seals (aka gasket) to make sure it's OK. Also check the door alignment to make sure that it is straight and parallel to the cabinet in case of a hinge problem not allowing the door to close correctly.
Here's the parts list that is useful if ever you need replacement parts. Locate the wanted part in the list and note the part number that is shown for the part. Search online for the part number only to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
to clarify, the only time the drawers were foggy was when I noticed the warmer temps. When I rechecked later on, and the temps were back to the normal range, all shelves and drawers were cleared up. But I will check seal around the doors. thanks.
@js2318
Being cold inside the refrigerator if you opened the door to view the temps then fogging could occur very rapidly especially if it was warm and humid outside.
Also you may find that once the compartments are stocked with items that during a defrost cycle, the temps won't rise that high as they will maintain it cooler for longer than just air alone
js2318 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 38
