Was watching a show then it went black screen
Screen went black in the middle of a show still can hear voice but can’t see a thing, why?
@sam84098 turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
crwdns2942667:0crwdne2942667:0 44
@sam84098 verify for us that your TV is a LN46C630K1FXZA If not, let us know what exact model your TV is.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
