Dryer stops running in the middle of cycle.
I have a Kenmore MOD 110.6192311, DWJR-ELE_2406026-FM24. The dryer has started shutting off in the middle of a dry cycle. I go in and hit start and it starts right back up. It will run for anywhere between 2 minutes and the end of the cycle before it stops again. I removed and tested the door switch, it might be faulty, so I jumped the wires and bypassed the switch, and still having the same issues. It also is not heating up like it should, but that more random then the shutting off.
Hi @mitchellmarx
Might be a problem with the timer and possibly also the cycling thermostat if it doesn't get hot enough
If it is the timer search online for WPW10185976 to find suppliers that suit you best. (examples only)
Here's a video that shows how to replace the thermostat that will help you to check if it is is OK or not.
If it is also the thermostat, search online for WP3387134 to find suppliers that suit you best. (examples only)
Here's the wiring diagram that may also help.
Mitchell Marx crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 39
