Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
Only 2sec window to insert disc when turning ps5 on
My playstation 5 i just bought from a scammer has a problem with disc drive
When you turn it on disc drive activates and starts sucking in a disc automatically, this is the only time you can insert a disc. Game will install normally. Disc also comes out when you press eject. And after that disc drive keeps on making noise for 20 secs. Not very loud or disturbing. Just odd.
Once the console has turned on, it no longer accepts a disc. The only way to insert a disc is to restart the console and feed it the disc during startup.
Edit: if disc is in when you turn console on the disc comes out.
Edit: there was some grime around the disc drive, i suspect sensors could be covered in something
Hi!
Hmm, sound like typical disk drive issues. The laser deck is OK so far I can see.
First, what you can do is to disassemble the drive and see what is happening in there. You can clean the sensors and the drive and see how that goes!
So far it does sound like the sensor(s) are bad or the mechanism. Could also be the PCB (hopefully not, because you can't replace this one).
If nothing is working, then just replace the drive and see how that goes (ALWAYS transfer the original PCB to the new drive).
Guide: PlayStation 5 Optical Drive Laser Replacement - iFixit Repair Guide (please leave the laser deck as it is, this is the closest guide I could get on Ifixit).
Please let us know how it goes!
Ka Ki crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 40
