The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
No display after installation of mod chip
Hi
I took my GameCube apart and installed a Pico board thing as I wanted to mod it. Followed a guide on YouTube from a guy I've watched before and following them. The GameCube turns on but has no light on the console it flashes orange but then nothing. I know it's on because I can hear the fan. I've got hdmi thing but that only shows a blue screen I don't know what's wrong exactly not sure if the hdmi thing isn't working or if it something to do with the actual console.
I've done as the guy in the video done with soldering soldered each point that needs to be done
If you need more information let me know hopefully someone can answer this
Hi!
Probably something is damaged during the process... Did you checked for solder splashes? All good? Did you also tried with the AV cables? That would be the first test to see if anything is happening or not.
Another test would be to take out the modchip and test again.
If both still failed, then you most likely damaged something during modding.
Please let us know if one of the tests worked or not. Thanks!
William Black crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 36
