The Google Pixel 7a is the budget-oriented variant in the Pixel 7 series. Released in May 2023, the Pixel 7a improves upon the Pixel 6a with face unlock, 8 GB RAM, heavily upgraded cameras, and wireless charging.
Why is my phone not fast charging after battery replacement?
I have replaced the battery following the guide without issues, everything works after completion. However, the phone no longer fast charge? It says that it's charging rapidly but only charging at 10w. Thanks
Fast charging will be done at 9V. It requires communication between the battery charging circuit and the charger. Obviously, the charger must support that. Assuming you have the same charger, then the cable must also be a data cable, not a charge only cable, assuming you have the same cable and it is not damaged, then something is not properly connected - assuming you have a compatible battery.
Hi, thanks for the reply. Charger and cable are the exact same ones I used prior to battery replacement, my wife has the same phone and it fast charges no problem with the charger. I will probably have to take off the back of the phone again and double check the battery connection.
K11NGUS crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 56
