The Stylo 6 is a midrange stylus-slate Android smartphone released by LG in 2020. Identifiable by model number Q730, followed by carrier or version-specific characters.
Phone has water damage and touch green issue
My phone has touch screen issues as a result of water damage the screen is also cracked
Hi @sheeshshawty
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well.
From what you said the screen will have to be replaced also
Hopefully after you have done all this the phone might work correctly again.
Here is teardown/screen replacement video for the phone that may help.
Search online for LM-Q730TM lcd display to find screen suppliers that suit you best. (examples only)
If this process seems too daunting, take your phone to a reputable, professional phone repair service, which is also experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
sheesh shawty crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 42
