Lenovo ThinkPad T14 Gen 2 Freezing and fan noise
Hi everyone, my Lenovo ThinkPad T14 Gen 2 laptop is freezing a lot and restarting on its own, it's also making a loud fan noise.
I can't use the laptop, it freezes within seconds of turning it on.
Pls help me.
I think that it may be a hardware issue. It could be the CPU heating up really quick and then shutting down. That would explain the fans, the laptop could just be overheating. You can test if this is true. You want to have your Laptop completely turned off. Then you want to start it up and while it goes through start up, keep pressing the F10 Key on your laptop, it should be up at the top of your keyboard. Then you're be in what's called a "BIOS". You can find your CPU temperature settings and see how its doing. Check if its overheating and then if it is not, do a memory check. If you have to check the memory. I would recommend going on chatGPT and then tell it what computer you have to the exact model and tell it that you want to check the memory in the BIOS but you need it step by step. It will guide you and if that doesn't work then have it give you some steps on what to do.
Rulla Dil crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 197
