Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
My device turns off when plugged into charger
when i plug charger after then display sleep the phone teun off and it trun on when i plug out the charger but if i trun display on while charging then no issu no hit issu battery health is 73 but still getting charge backup almost 5 hour i got e crash report
{"bug_type":"210","timestamp":"2025-08-20 17:48:15.00 +0600","os_version":"iPhone OS 18.6.1 (22G90)","roots_installed":0,"incident_id":"4F0BAFC0-331F-4BEE-9E83-D9EC0C42586F"}
"build" : "iPhone OS 18.6.1 (22G90)",
"product" : "iPhone11,2",
"socId" : "8020",
"socRevision" : "11",
"incident" : "4F0BAFC0-331F-4BEE-9E83-D9EC0C42586F",
"crashReporterKey" : "73667f81116119e7f3bce851cc994a406852b341",
"kernel" : "Darwin Kernel Version 24.6.0: Tue Jul 15 21:53:59 PDT 2025; root:xnu-11417.140.69~16\/RELEASE_ARM64_T8020",
"date" : "2025-08-20 17:48:15.51 +0600",
"panicString" : "panic(cpu 2 caller 0xfffffff00e0697b8): \"i2c0::_checkInterrupts error interrupt; last read status 10810100 int shadow 00810100 xfer 80000000 fifo 00000003 for device ad5860\" @AppleS5L8940XI2C.cpp:503\nDebugger message: panic\nMemory ID: 0xff\nOS release type: Not set yet\nOS version: Not set yet\nKernel version: Darwin Kernel Version 24.6.0: Tue Jul 15 21:53:59 PDT 2025; root:xnu-11417.140.69~16\/RELEASE_ARM64_T8020\nFileset Kernelcache UUID: 06C754C9114643DD5A366A671102A6AF\nKernel UUID: F960EF84-B35E-3AF9-87AE-D6E399CE13BA\nBoot session UUID: 4F0BAFC0-331F-4BEE-9E83-D9EC0C42586F\niBoot version: iBoot-11881.140.96\niBoot Stage 2 version: \nsecure boot?: YES\nroots installed: 0\nPaniclog version: 14\nKernelCache slide: 0x0000000004d84000\nKernelCache base: 0xfffffff00bd88000\nKernel slide: 0x0000000004d8c000\nKernel text base: 0xfffffff00bd90000\nKernel text exec slide: 0x0000000005bc0000\n
It appears the phone's processor is having an issue with the device referred to as the ad5860, which is a chip inside the Taptic Engine. Generally the fix for this in at least one other case is to replace the charging port flex cable assembly. See this previous question for more information; it's regarding a XR rather than a XS, but the sensors and causes are the same.
SOLVED: iPhone Xr randomly bootloop at random moment - iPhone XR - iFixit
iFixit doesn't have a complete guide to replacing the lightning port flex cable assembly, but the Spanish site Nadie Me Llama Gallina has just what you need.
Manuales / Apple iPhone Xs / Flex with load connector and lower microphone - Nadie Me Llama Gallina
Since part of the procedure for replacing the charging port is to remove the battery, I strongly suggest you go ahead and replace it at that time. The official standard for replacing the battery is when it gets below 85% capacity; yours is definitely living on borrowed time.
Rahat Islam crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 37
