iPhone restarts every 3 minutes after getting wet
i took apart the phone, cleaned everything with isopropyl alcohol put it back and issue still persists, then i came across then i came across teh iphone kernel panic page here! and thats my exact issue, so i did everything, got the logs read through it briefly and i found this
"panicString": "panic(cpu 3 caller 0xfffffff0264fb62c): userspace watchdog timeout: no successful checkins from thermalmonitord (2 induced crashes) in 200 seconds\nservice returned not alive with context : is_alive_func returned unhealthy : current 6ffffffffffff, mask 37ffffffffdff, expected 37ffffffffdff. SD: 0 BC: 1 RC: 0 BS: 2, Missing sensor(s): Prs0 \n
i looked through other forums and i found that it means the lightning flex cable is damaged (prolly from the broken back + glass water)
heres the whole kernel panic ( i changed the file extension to .json so it gets formatted by vscode) https://filebin.net/q6l2o1eazfo7u5l6
and also i mustve messed up the dot projector when taking the phone apart because face id doesnt work anymore for some reason
