Wheel hub Bearing repair
- How do I safely repair wheel bearing and hub
This is a simple job, I did mine recently. Raise and set truck on jack stands, unbolt the caliper and use a wire to hold it up and keep strain off line,remove the caliper retaining bracket 22mm I believe. Once those 2 bolts are out there’s 3 bolts from behind that hold the hub assembly in place. Before removing the bolts, disconnect the abs wire up at the connector on the chassis then proceed with the bolts. U might need to persuade it with a hammer if you’re up north. If it’s 4x4 you’ll need to undo the axle nut. Reverse the process and should take under 2 hours tops. I did mine in an hour and a half and have a medical condition that affects my breathing and I used all hand tools. Just work safe!
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 25
