DeLonghi ECAM Series. Modelnames are Intensa, Magnifica, Primadonna, Eletta, Dinamica. Look for the label on the bottom plate.
General alarm error will not go away
My DeLonghi ecam 35075 start a cycle when I turn it on it runs water through the spouts. Starts heating the water for a couple of minutes. It then goes to general alarm, and I can’t do anything. I’ve cleaned everything inside and out no change. Any suggestions?
@michaeltho48455 let's see if our coffee maker guru @vauweh has a solution for you.
"General Alarm" means everything and nothing... In this case I suppose a broken thermosensor or the heater itself. Use the testmode and proof the function. We have a wiki with solutions, unfortunatally it is not translated yet in english. Read this wiki using e.g. google translate.
Thanks for the suggestion. The link to the wiki didn’t work. Do you have an alternative method to reach it?
@michaeltho48455 Try iFixit swap to german language.
Found the link on the German site, but it seems to be broken from there as well. “Too many redirects “ error
@hellebunzel You will see the Wiki, when you switch the language of iFixit completely to German.
Thank you! I got there!
Michael Thompson crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 145
