Sony XBR-55X900F 4x red lights flashing after dark screen
Sony XBR-55X900F
4x red lights after firing up with Sony logo and circles. Does this over and over. I don't want to purchase unnecessary parts. Can you help? Les
@lesterstoker the 4 blink error code for your TV is a LED driver failure/LED voltage protection [LD_ERR] error. Two things are common. Your LED driver board or your backlight strips. My money is on the backlight strips, which is fairly common for Sony TV's
Here are the flowcharts for the LED driver board 4 Blink Error Code
The problem here is that your TV uses a circuit which knows when your backlight strips are weak/filed and will give you this code. There might be a way of bypassing that but we would need to see the boards and their connectors (with legend). Sometimes bypass the error detect will work. Post some pictures of your boards with your question. Adding images to an existing question
Here is how you would need to change the backlight strips Not the identical model but identical work.
Expensive? No. PITA? Definitely.
Lester Stoker crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 58
