My charger port is loose and not charging
I've had this phone for a while and idk if it's from use but I need to know should I get it repaired or something else.(any help will be much appreciated)
@zacargentum since it is loose, it may just need to be re-soldered. Of course it is also possible that it had broken traces or it may even be a bad Sub_board. I would suggest to change that bord since the repair is fairly straightforward and the cost is really not that expensive. Use this guide Samsung Galaxy S24 USB-C Port and Daughterboard Replacement for the repair.
Before you get it repaired attempt to clean out the charging port first, gently use a can of compressed air or a wooden toothpick or you could use a toothbrush to gently get into the charging port to get out any debris. If this fails you may have to get a repair.
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 200
