A midrange Realme phone released in September 17th, 2020. It packs a 6.5" 720p IPS screen with 90Hz refresh rate, Snapdragon 662 and up to 128GB of storage. Not to be confused with its European variant, which is basically a rebrand of Narzo 20.
mengapa hp saya mentok logo terus mati
Translation Indonesian - English
Why does my phone keep getting stuck on the logo and then shutting down?
My phone keeps getting stuck on the logo and then shutting down.
@arjunsunjana your phone seems to be boot ;looping. That is commonly caused by softwre/firmeare issues and not hardware related. On here we deal more with the hardware aspect of repairs. In general I suggest a force restart. For you phone you would need to
  • press and hold the power button and volume up button simultaneously for about 10-15 seconds until the device vibrates and restarts.
Next see if your phone works in safe mode. If it does you know your phone's issues are related to a third party App. You would then need to find that app and delete it. To get into safe mode:
  • Power your phone off completely.
  • Press and hold the power button until the Realme logo appears.
  • When the Realme logo appears, quickly press and hold the volume down button until the device boots up.
  • If successful, "Safe mode" will be displayed in the bottom left corner.
If that does not work, you can try and boot into recovery mode and at least clear your cache to remove any files that maybe corrupted etc. It is also in this mode where you can do a factory reset. Do not do this unless you have your data (pictures, contacts, SMS, music etc.) backed up. When you do a factory reset you will delete all of those.
To et into recovery mode you need to:
  • Power the phone off completely.
  • Press and hold the power button and the volume down button simultaneously.
  • Release the buttons when you see the Realme logo or the Recovery mode screen
For more or even better suggestions, you really should check those forums that deal with soft/firmware issues like the realme community as well as this one
Arjun Sunjana crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 43
