PowerA Enhanced Wired Controller (Xbox) features a headset dial, a detachable 10ft USB cable, and mappable buttons.
Can I fix the left joystick click in not activating?
When I go to click in on the left joystick, it will not activate (usually to sprint in most games). Everything else seems to be working, and I've even changed out the joysticks. Not sure if this would need a flatout motherboard replacement, or if something else could potentially be done. Any help appreciated. ^+^
Have you cleaned the connecting points? Sometimes contact cleaning spray can do a hell of a job when you experience missing controller signals. You changed the joystick and it still doesn´t work which means there must be a connction problem with for example the cupper lines or it´s less likely a weird software bug which you may fix with a reset.
@Cafugo I did break it down at one point and everything seemed (to my untrained eye) to be fine, but i did use some isopropyl just to clean around the contacts (not sure if that was the right stuff to use). As far as a potential software bug, how would I go about resetting it?
I´m not familiar with the exact modell, but there could be a small hole an the backsite which usually works as a reset button.
CHAOTIC426 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 91
