The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
How to turn on MacBook air 2014 when 100% battery drain
I have MacBook Air early 2014 with a i5, 4GB RAM with 128GB SSD, it has OpenCore & macOS 13.
Problem is today when I turn it on its say low power, so I connect the charger but is detecting charge but in settings or click icon in bar its says battery is not charging so I check system information and in there it says battery normal also show charger watt so shutdown it so SMC reset and went into diagnostic its battery is not charging so disconnect charge and try again I try it, it didn't work and not powering on even plugged in no charge, after disconnect battery in mac, I try to run using charging power no sign of running even try SMC no sign even plug battery wait sometime and tried SMC no response.
I don't how to fix because I no money to get professional help or apple help
Pls help me how to fix it!
This question was migrated from https://meta.ifixit.com/Answers.
Did you ever replace the battery? Given the age of the system I'm suspecting your battery is bad MacBook Air 13" (Late 2010-2017) Battery
crwdns2886500:0An aftermarket replacement battery compatible with a MacBook Air 13" laptop.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$69.99
Battery in good health It can hold charge upto 3 to 4 hours a day without plug in my charger also system information says battery is normal
@minimano - I thought the system was dead? If it’s working let’s get a better idea as I find Apples health system glosses over some important data points. Let’s get a better tool install this app CoconutBattery Take a snapshot of the main window and post it here so we can see it too.
System not turning on,battery power 100 drained not power on using ac power
@minimano - So we are a dead fish here😕
I assume you don't have a bench power supply, or DVM, or any deep electronic and soldiering skills to dive deeper into the circuitry.
While getting a fresh battery is something just from an age perspective you likely need digging deeper into the why it is not charging getting into the charging circuity within the systems main logic board.
Sadly you will need to find someone locally to help you and there are likely some costs here for the needed parts as well as the deeper skills to diagnose at the deeper level.
Mini Mano crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 69
