The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
Is my Nokia N8 dead or just the battery?
I have an old Nokia N8 that I’ve been trying to revive. It hasn’t powered on in years. I first tried charging it using the original Nokia AC-3U charger via the barrel port — nothing happened. Then I tried charging it via MicroUSB and left it plugged in overnight (around 8–9 hours), but still there was no response at all — no lights, no vibration, and the screen remained off.
I opened the phone carefully and disconnected the BL-4D battery. I measured its voltage with a multimeter and saw it was extremely low — around 2.7–2.9V after attempting a jumpstart, but within minutes it drops back down to nearly 0V. I’ve attempted jumpstarting it a few times but the battery won’t hold any charge. I also tried checking if the phone would power on when plugged in with no battery, but nothing happens — no indication of power.
I have another battery from a different phone (an LG GS190), but it's wider and the contact pins don’t match, so I can't use it. Given all this, is there anything else I can do to test whether the phone is still functional?
Batteries done. These older phones show absolutely zero signs of life without a proper working battery
I was jumpstarting some other 2 phones (and 1 camera) 's battery and successfully revived one, the other phone and camera is retaining charge but not above the minimum charge threshold. I havent tried jumpstarting it over 3VOLTS, so I might try that.
Working phone: LG GS190
"Retaining charge" phone: Samsung SGH-X700
"Retaining charge" camera: Canon PowerShot IXUS100IS (or similar)
Buy a new battery.
Sai Panneerselvam crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 97
