Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
Is v4 controller compatible with joystick replacements on ifixit
Is my v4 controller compatible with joystick replacements on ifixit store if not where can I find a good quality replacement that's compatible with v4 dual sense controller
Hi!
You can find them anywhere actually!
As example on AliExpress: Replacement Hall Effect Joystick 3D Analog Sensor ThumbStick for PS5/PS4/Xbox One/Series Controller Repair Parts Accessories - AliExpress 44
As long as it is for the PS5, you can use those joysticks also from the iFixit store!
I would recommend the Hall Effect ones! They are great and you have way less risk that it will drift!
Please let me know how it goes!
That doesn't answer my first question if the product on THIS website is compatible for my controller. Also when researching the topic I found that the v4 controller can have a ALPS 2.1KΩ potentiometer (green) or Favor Union (FU) 2.3KΩ potentiometer (orange). The product you recommended is orange meaning it could have 2.3k ohms as a resistance value (I don't know much about the product you recommended). but my controller has a green potentiometer meaning it has 2.1k ohms resistance value so I don't think that one on AliExpress would be compatible with my controller. So again I ask Is the product (PS5 DualSense Controller - Gulikit TMR Joystick) by Ifixit.com compatible with my controller (is it 2.1k ohms) but the potentiometer on it is black and doesn't list it's resistance value (if it's 2.1k ohm or not). I don't want to install the wrong one and waste my time with this so can anyone tell me if this will be a problem for my controller or not.
The green and orange ones are different. The orange ones are the Hall Effect joysticks and the green ones aren't. The hall effect ones do have tiny magnets and are actually taking care of the drift. Those can be used from V1 till V5.
The Gulikit (green ones from iFixit) are high end joysticks from a original brand. Those are also very good and can be used by every PS5 controller from V1 till V5.
If you want to be like 100% sure, then go for the Gulikit ones with the same ohms. They *should* fit your controller! Otherwise they should show that it's only regarding the V1, V2 etc.
Ok when I get a chance to order the Gullkit one I will test it. if gullkit doesn't I will try the AliExpress one then post the results on here afterwords. Thank you for the help!
Alright! My pleasure! Please let us know how it goes :)!
John crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 33
