My pc keyboard connection is disconnected I want to reconnect
My pc keyboard connection is disconnected I want to re connect and some keys won't work
To reconnect your PC keyboard and troubleshoot the keys that won't work, try these steps:
1. Check the Physical Connection: Ensure the keyboard cable is securely plugged into the PC's USB port. If it's a wireless keyboard, check the battery level and ensure it's properly paired with the PC.
2. Restart Your PC: Sometimes, a simple reboot can resolve connectivity issues.
3. Test the Keyboard on Another Device: If possible, plug the keyboard into another device to see if the issue persists. This can help determine if the problem is with the keyboard or the PC.
4. Update or Reinstall Drivers: Go to your PC's device manager, find the keyboard section, and check if there are any driver updates available or if reinstalling the drivers is an option.
5. Check for Stuck Keys or Debris: For keys not working, gently clean around the keys to ensure no debris is causing the issue.
Does this help you troubleshoot the issue 🖥️? Do you need more specific guidance?
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 39
