Screen not showing but has sound
Vitron TV screen too dark
@johnpaul90232 we will need to know the exact model number for your TV.
The no video issue can be related to a bad backlight inverter circuitry. A simple check for that would be to darken the room and turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
How can I fix MeWe TV doesn't make video audio only
How can I repair a MeWe TV model that does not show video and plays sound
Please add the model number to your question.
The first thing to do is to follow the instructions already laid out by @oldturkey03 then come back and tell us what you found.
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 51
