An all-rounder: coffee, espresso, cappuccino, latte macchiato, tea water, hot milk. Simple operation with touchscreen.
Milk frothing problem with Siemens EQ.6 Plus s100
Hi all,
My Siemens EQ.6 Plus s100's milk frother system suddenly stopped working properly and I cannot find my answer elsewhere online. I've tried a couple of things but it has not yet solved it so any further tips would be much appreciated!
Some points:
  • The milk is being sucked up into the tube, but nothing comes out
  • I clean the machine weekly and I've ran a cleaning cycle as well as multiple milk system cleaning cycles. When I clean the machine I also take off the cap at the front and the two plastic parts where the milk and coffee are being dispersed from
  • The same milk is being used as always
  • The tube I've bought a couple of weeks ago and is fine (no leaks)
Any help would be much appreciated!
@sebastiaan42799 I think your device has an issue with the air inlet/ filter. You will find this inlet in the end of a clear hose made from silicon connected to the ceramic valve. See this guide, step 7, the clear hose going upwards. Replace it with a new one and your frother should come to live again!
Thank you so much!
Do you think it is the same part as this one:
https://www.koffie-onderdelen.nl/Slangad...
The description of the part is: This hose is found directly on the electric ceramic valve where it attaches to the heating (element).
@sebastiaan42799 I don't think so. There are two types of filter. Here the other one. I think you should open the device and choose the one which fits exactly.
If you can't find a supplier from the Netherlands take anyone from Germany, I think they ship to any country in the EU.
@sebastiaan42799 At last I found fiyo from the Netherlands.
Thank you so much for all your help, it is incredibly appreciated! Time to order the part and follow your guide to replace it :)
Sebastiaan van Lidth de Jeude crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 363
