ZUMO XT battery died. Replace with Battery# 361-00077-00? Connector?
Garmin is silly. My ZUMO XT GPS battery went bad. They say I have to send it back. F' that. I want to fix it on my own...or with your help. Battery# 361-00077-00 is what Batteries Plus said I should buy, however, the connector is part of the problem. Anyone have experience in this world?
@jasonb27686 My information says the battery is a 361-000133-00 but whatever the case may be, none of those are readily available. I would search for a battery with same electrical characteristics (the amperage has some tolerance) and a size that will fit the case. Then cut the wires and connector from the old/original battery and transplant it to the new one. Lets see your original batteryAdding images to an existing question
On the GPS forums, claims are made that the 361-00077-00 fits all Garmin Zumo's but the connector is the real issue here.
Okay, looks like the battery is a 3.7V 3060mAH 11.322WH battery and the Garmin number indeed is a 361-00133-00. Now, the battery itself is a 1ICP5/40/62-2 battery with 3 leads (Positive, Negative and thermal protection). Commonly this means your battery size is 5mm thick (in the case of this battery it might just be 10mm, got a feeling here;-) by 40mm wide and 62mm long. Do a search by the 1ICP5/40/62-2 numbers and see if those match your battery.
If my numbers are pretty identical to what they measure on your battery, something like this (example only) will work
Jason B crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 388
