This page offers repair and further information about the Craftsman Generator 580.325610, a portable power source that generates 120 Volt AC, 20 Amp, single phase, 60 Hz electrical power, and has a starting wattage of 8600 watts and running wattage of 5600 watts. The generator includes features like a double pole circuit breaker, choke lever, and a fuel valve.
How do I drain the gas
How do I drain the gas from the craftsman 6500 Generator?
First you siphon off the gas tank. Second you push or unscrew the spring loaded screw under the carburetor. This drains the bowl. If no screw, pull off the rubber gas (from tank) supply hose.
@tomroth drain it from the tank valve underneath the tank. Something like this should work well for you.
Tom Roth crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 44
