Information and repair guides for dehumidifier repair, an appliance that removes humidity from the air in your home.
Compressor not coming on
Why is the compressor not coming on
Hi @valeriefinn,
What is the make and model number of the dehumidifier?
Saftey Warning Most compressor-based HVAC equipment including ACs and dehumidifiers runs directly on 120-volt AC or more often than not 240vac do not poke around in them if you are not comfortable working with wall outlet voltages all units contain capacitors that hold charge even when unplugged.
  • Unplug and unpower the unit
  • Next, use a 300V-rated insulated tool to discharge the fan and compressor starting capacitor.
  • Next, using a multimeter in MFD ( (µF) ), or capacitance mode ( ┤├ symbol ) measure the capacitance from C or common to HERM or H compare the results with
Valerie Finn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2959996:0crwdne2959996:0 271
