This is a Dell Latitude device, identified by the model number 7420. It features a carbon fiber case, touch screen, and a finger print scanner to unlock it.
dell is turning off after 5 sec
Im having problem with my 7420. It turning on after 5 sec. turning off and caps lock start light for about 10-15 sec and turning off .. Does anyone know what can cause that problem??
  1. LED is blinking 3 times orange 6 times white
Hi All. I have solved this problem. Turn off laptop, disconnect him from power supply, keep CTRL and ESC together connect power and when DELL logo appears release CTRL and ESC but first on USB drive formated to FAT32 upload BIOS_IMG.RCV dowonloaded from dell.com/support then chose recover from USB and do what is writed on screen
Thema closed :)
Hi @tomaszsikora
On p.80 of the service manual it shows that a 3:6 error code is caused by a Flash corruption detected by SBIOS and the fix is to replace the systemboard.
Try the following procedure to try and reset the BIOS and check if it resolves the problem.
  • Turn on the laptop and wait for Dell logo to appear
  • Press and hold the power button down for 35+ seconds until you see the power light flash 3 times.
Hopefully it will start and boot OK the next time the laptop is turned on.
If not, repeat the last step, download the latest BIOS to a USB Fat32 drive, switch on, keep tapping F12 then update the BIOS from the USB drive.
Thema closed :)
Tomasz Sikora crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 117
