Infinix Note 12 Specifications 2023 Model It was released on 2022, October 06. It has 6.7 inch, AMOLED, a resolution of 1080 x 2400 pixels screen. It uses MediaTek MT8781 Helio G99 (6nm) chipset, Octa-core (2×2.2 GHz Cortex-A76 & 6×2.0 GHz Cortex-A55) CPU, Mali-G57 MC2 GPU.
Change glass of the phone
My phone glass is been broken how do I change it
How to change my phone screen
Password forget
This video guide will show you how to replace the screen on an Infinix Note 12.
Infinix Note 12 LCD Replacement - YouTube
You have to remove the rear cover and camera lens cover, unscrew the midframe and remove it, then take out the battery. This will allow you to access the flex cable connecting the screen to the motherboard, which you'll unplug and peel off of the metal frame. At that point you can use heat and/or alcohol to soften the screen adhesive, removing it with tools such as an opening pick and a suction cup. Clean off the old adhesive and assemble the phone far enough to turn it on to ensure the screen works before gluing it down.
Tape down the glass so you won't end up with shards everywhere. Heat the glass with something like an iOpener, and take off the glass with a suction cup. Replace.
crwdns2889612:0crwdne2889612:0 -1
Rd Prince crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 397
