Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
Water adhesive for speaker after replacing battery
Hello, I haven't seen Ifixit done this guide before, but should I buy a speaker water seal adhesive after replacing battery? Ifixit recommends removing the speaker and haptic engine in order to remove the battery, but would that be compromising water resistance in the lower speaker? Or not? should I buy a new adhesive for the lower speaker or should I leave it like that and just use the screen water seal adhesive.
If you intend to remove the lower speaker, yes. Replace the gasket. It is nigh impossible to get the existing one out intact and it will compromise the water resistance. I would definitely recommend replacing it.
crwdns2886500:0Replace the adhesive foam gasket that fits between the loudspeaker and the speaker opening in the rear case compatible with iPhone XS. This gasket helps seal liquid and dust out of the device.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone XS Loudspeaker Adhesive Gasket
$0.99
Russ Torrez crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 48
