Repair guides, user manual, and useful links related to the Acer Chromebook C730-C4V9 will be provided on this page. The Acer Chromebook is a sleek and stylish laptop device that is useful to a wide variety of audiences.
Where is the write protect screw chromebook C730
Hi. Could someone tell me where the write protect screw is please? I'm a complete unco so if possible could you please circle it if you don't mind? I'm just trying to put Chrome OS Flex on my old Chromebook C730 and this is what I was told to do. Thank you
Hi John,
The C730 model spanned a time frame from 2014 to 2019. However, with the advent of the C50 security chip in 2017, Chromebooks no longer came with a write protect screw, so it's going to depend on exactly when your laptop was made as to whether it has a write protect screw or not. A site called MrChromebox.tech has a good writeup about the various Chromebook write protect schemes in use.
Firmware Write Protection on ChromeOS Devices
Generally it is clearly marked on the motherboard, and I don't see one on yours, so I'm guessing you have a later model that uses the security chip instead. All may not be lost, however, as they point out that early models using the chip would allow you to disable the write protection by unplugging the battery. Here's a quote from their site.
Obviously the laptop will have to be plugged in, but according to this you may be able to bypass the write protection by running without a battery until your upgrade is complete.
Hi Jerry.
Thanks so much for your detailed response! I just saw a sticker on the back and it's manufacture date was 2015/04/09, so I think that means it might have a screw somewhere to remove
Cheers
John
John Jurisic crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 88
