Odd trackpad button clicking noise
This morning, my 2 year old MacBook's trackpad button started making these clicking noises every time I pressed on it. But it also depends on where I press down. The noise would be there on the right side sometime, and sometimes on the left. What could be wrong? Thanks
What exactly do these clicking noises sound like? How do they differ from that of a normal click? Is the actual upper case surrounding it broken in any way?
Normally, the sound it would make would this dull, quiet, *thuck*. Now it's this metallic, loud, *CLICK*. Sounds like a spring inside is in the way or something
Something very small could be stuck under your click pad. Try to insert the corner of a paper sheet under the click pad and slide it to remove the "intruder" out. Or buy the newer MacBook Pro, there's no click pad anymore in the trackpad assy LOL...
crwdns2889612:0crwdne2889612:0 7
Placed a piece of paper, moved it gently and found some slight resistance. Move the paper in and out and out popped a piece of dirt or food particle? Either way, after years of an annoying high click sound its back to normal!
Thanks!
This helped quiet the noise in the left click a lot -- thanks! Wonder if there's something that would complete the process? It's still a little noisier than the less-used right click.
Thank You So Much
I just had the same thing happened and I held down the button and blew really hard into the area. Good as new! A trusty old Nintendo trick! :)
crwdns2889612:0crwdne2889612:0 10
this is amazing!!!!!!!!
Worked right away!
omg this worked!!!!!!!
this actually worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wtffffff, just workeddddd!!!!!
Try tilting the Book and see if you can get the obstacle into a corner, tapping the button lightly. Then use a business card to push it out.
it just worked for my dell, the problem is little particle of dirt or food , stick a small piece of paper in the edge around the touchpad thing and go all the way around then blow all the way around really hard and it should fix it. i promise, may not seem as if thats the problem but it is. it did fix mine.
10858083 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 24,310
