Power button on of problem
crwdns2889612:0crwdne2889612:0
0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 92
Past 30 days
crwdns2934271:0crwdnd2934271:0 bablu shaik crwdne2934271:0
==== 1. Check the Remote Control First ====
* Make sure the TV responds to the remote’s power button.
* If the remote works fine, the problem is likely with the physical button on the TV.
==== 2. Inspect the Power Button Physically ====
* The button might be stuck or dirty.
* Gently press it multiple times to see if it loosens.
* Use a can of compressed air around the button to clear dust or debris.
==== 3. Unplug and Power Cycle ====
* Disconnect the TV from the power outlet.
* Wait for about 5 minutes.
* Plug it back in and try the power button again.
==== 4. Try the TV’s Other Buttons ====
* If your TV has other buttons (volume, channel), check if they respond.
* If all buttons are unresponsive, the issue might be with the control board.
==== 5. Inspect the Internal Button Connection (Advanced) ====
* If you’re comfortable opening the TV:
** Unplug the TV.
** Remove the back panel carefully.
** Locate the power button assembly on the mainboard.
** Check if the button or ribbon cable is damaged or loose.
** Clean the button contacts with isopropyl alcohol.
* Only do this if you have experience with electronics and the TV is out of warranty.
==== 6. Use the Remote or External Device ====
* Use the remote control or connect a device like a universal remote or smartphone app (if supported) to turn on/off the TV as a workaround.
==== 7. If Button is Faulty ====
* The power button assembly or control board might need replacement.
* Contact Sony support or a certified repair center for parts and service.
crwdns2934271:0crwdnd2934271:0 Asha Kanta Sharma crwdne2934271:0
@i_am_the_cosmos AI Generated Technobabble
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@bablushaik what exactly is it that your TV does or does not do? Does your Power LED still light up? Does it blink? Can you verify that your TV is a Sony KDL-32W670A? We need more details.
