Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
🔧[BDM-020] R2 Trigger Permanently Activated – Even Without Flex Cable
Hi everyone,
I’m dealing with a PS5 DualSense controller (BDM-020) that has a persistent issue with the R2 trigger input being stuck "on", even when no trigger or flex cable is connected.
Here’s a full breakdown:
Symptoms:
  • R2 is always registered as pressed, even without the flex cable or trigger module connected.
  • When I reconnect the bumper flex cable, R1 works, but R2 remains constantly active.
  • The actual R2 trigger module works fine on other controllers.
  • I also tested other working trigger modules on this board – same problem: R2 stuck.
  • I noticed that the pins of the flex cable seem to bend slightly when inserting the cable inside the FPC connector (trigger flex slot), which might suggest mechanical damage to the connector.
Board info:
  • Mainboard: BDM-020
Questions:
  • Has anyone encountered R2 input being stuck "on" at the board level, even with no flex cable?
  • Could this be caused by damage to the FPC connector, e.g. shorted or internally bridged pins?
  • Is it possible to replace the trigger FPC connector or clean/fix individual pins?
  • Any specific points I should probe with a multimeter to isolate the issue?
I’d love to hear any suggestions – I’d prefer to repair this board if possible instead of scrapping it.
Thanks a lot in advance!
Was there a fix for this. I am experiencing same exact issue same board and all.
Was this issue fix found? I am experiencing same exact thing with same board
Hi!
Maybe my answer could help you?
If not, please raise a new question.
Thank you!
Hi!
Did you also tried replacing the button circuit membrane?
If yes, then you might want to check the traces on the motherboard as well.
Regarding the FPC connector, can you share a picture with us? It is possible that it is damaged and need to be replaced.
In rare occasions, it could be caused by the analog sticks.
Thanks in advance!
beliebiger crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 223
