The Airpods Pro 2nd Generation is a revision to the original Airpods Pro. Released on September 7th, they allowed better audio, 2 times more noise cancelling, and volume controls. It also boasts a larger battery, and a speaker on the case to make finding them easier.
AirPods case shows 3.5V at pins but doesn’t charge the earbuds
Hi,
I received an AirPods case for repair. The problem is that the case won’t charge the earbuds, and the earbuds remain off when placed inside.
I measured the voltage at the charging pins inside the case, and it reads around 3.5V under normal conditions. The battery seems fine — it’s not swollen and holds a charge.
What could be the cause of this issue? Is 3.5V at the pins normal, or is there another component that might be faulty?
Any suggestions or guidance would be appreciated.
Thanks!
So if the case is outputting charge, then its not charging the earbuds, then it seems the pads on the earbuds are faulty
So it could either be faulty charging pins on the earbuds themselves, or faulty battery in the earbuds, or some cable/charging circuit leading up to it
Mohammad naderi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 62
