The Salter model 1036 is a digital disc kitchen scale with a maximum capacity of 5 kg or 11 lb.
Incorrect battery makes it seem this is broken
Summary answer: CR2016 physically fit, but won't work - double-check that you have the right battery!
Hopefully not too naive a question, and I have the answer: using a CR2016 instead of a CR2032 will make it physically feel as if you've added a fresh new battery, but it won't work.
I ended up coming on here to try (and then succeed) to open the device up, only to try a battery swap to prepare to test anything I might do to fix it, and then find that everything was actually fine!
CR2016 physically fits, but won't work - double-check that you have the right battery!
Dave Donaghy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 31
