The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Do I need a new motherboard replacement?
A long while ago, the pad on my 3ds xl circle pad snapped in half, so my dad and I bought a replacement off amazon. As we were taking everything apart, the lock for the ribbon cable on the ZIF connector broke. My dad ended up soldering wires to the circle pad connection points to get it to work.
I want to do a re-shell in the future because all the factory paint is chipping off from sweat and sun damage, however with how the hard wire is setup, it would make it rather difficult to take everything apart. Because of the ZIF connector lock being completely snapped off, would I in turn have to replace the entire motherboard? I doubt such a small connector can be sold separately, but I thought I would ask regardless.
Hi Justin!
The ZIF connectors are for sale!
You can buy one, but this does need to be soldered in.
You can buy the part here (EXAMPLE): JCD 4Pin 21Pin 41Pin 53Pin FPC Female Socket Motherboard LCD Display Screen Flex Cable Clip Ribbon Connector For New 3DS LL XL - AliExpress
Otherwise, you can buy a broken (donor) motherboard and get the connector from there.
You can also desolder it, and then later when you've swapped everything, solder it back in!
A new motherboard is possible, but expensive.
If you need anything else, please let us know!
You don’t necessarily need to replace the entire motherboard. The ZIF connector lock can sometimes be replaced separately, but it’s a delicate job. These locks are very small, and sourcing one for the 3DS XL can be tricky, but they do exist on parts suppliers or eBay. If you’re not comfortable with micro-soldering, it might be easier to get a replacement motherboard since the repair is quite advanced.
Justin crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 132
