Repair information for the Legion Go, a handheld gaming console made by Lenovo, released on October 31, 2023.
Legion go black screen issue
Power on but no display, the issue happened after changed the thermal grease with battery disconnected. but then after changed the thermal grease and thermal pad, it stopped working now.
1.CHECK BRIGHTNESS AND ALSO TRY TO CONNECT TO AN EXTERNAL DISPLAY.
2 FORCE RESTART, power off the device and then power it on after 15 seconds.
It is not brightness issue and connected to external display not function all.
Tried force restart and follow the guide from reddit hold down volume up + power button to reset the device. still no luck, but once it a while the device can be turn on. when i plug in ssd or reopen the heatsink and put back, but now no more luck. i believe may be is due to static electricity or other electric leakage issue, cause the lenovo backplate case the screw see got electricity while charging.
Chun Siong Lee crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 34
