The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
New 3ds xl barrel wont go back in
I replaced my new 3ds xl top frame but when it seems impossible to push the barrel back in. I have tried pushing it while the console is closed and almost open. It almost goes in while pushing it while the console is nearly open, but it doesnt seem to go fully in. The exposed part of the barrel is a little damaged from trying to push it, but i dont know if it changes anything. If i close the console while its almost in (from trying to push it from the open position), it just pushes itself out.
Update (07/09/25)
had to compress the video heavily but i hope this could help
The images on the bottom show the condition of the barrel. Im not sure if it matters, but the condition is a little rough from trying to get it in.
In the background it shows what position the barrel was in (white tab down) , when i detached it from the lower frame.
Theres not alot of videos online about taking apart the n3dsxl, so the position of the barrel could be wrong, in the top photos there are the two possible ways it could go in, with the white tab up, or down. I have not tried putting it back with the white tab up, but i dont know if its recommendable since i have not seen anyone else put it like that.
Hi! Is it possible for you to upload photo’s or a video?? Then we can check what’s going on! Thanks in advance!
The barrel with or without the display ribbon!
@dan0 i updated the question with a video.
Hi!
It does seems like it’s almost in.
Is the top frame a aftermarket part? If this is the case, I’ve heard that it’s sometimes really difficult to get the hinge in.
What happens if you try to do the same for the original top frame you still have? Does this work? If yes, then there must be something off regarding the new top frame… could be milimeter work unfortunately.
I would try that first and see how it goes!
crwdns2944067:014crwdne2944067:0:
Yes i still have the original top frame. The seller i bought the new frame from did say it was an original, and it does look like it is. If i take out the frame, should i compare the two, and what can i do to the new one for the barrel to fit?
Have you got the right barrel in the right side?
@ted53890 I think so? I had previously taken it out at put it back 2 times to see if it was in the right place. Would you be able to tell by a picture?
Yes, you can compare them, but sometimes it's really hard to see. Does it work with the original top frame? If yes, then there is something wrong with the other one. If not, then you need to check if you have the right hinge on the right side.
@dan0 Can you tell from a picture if the barrel is in right? I can take the barrel out and show you. Im not really keen on putting back the old frame since i hate working with the ribbon cables, so id rather do everything else i can
crwdns2934275:09crwdne2934275:0
emb crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 166
