Why is my laptop start heating under 5 minutes
why is my laptop starts heating under 5 minutes i want solution for this problem
2. Poor Cooling or Dust Build-up
Symptoms: Heat from keyboard/base, fan always on or unusually loud.
Causes: Dust blocking vents or fan, Thermal paste dried out, Faulty or weak cooling system (especially in older or thin laptops).
Fix: Clean vents with compressed air, Use a cooling pad, Consider repasting CPU
Well High Background CPU Usage can also be the reason for this kind of issue so i will suggest you to Open Task Manager (Ctrl + Shift + Esc) → check CPU usage and end the unnecessary tasks.
If your laptop heats up within 5 minutes, it could be due to dust buildup, blocked vents, or a heavy background process. Try cleaning the vents, placing it on a hard surface (not a bed or pillow), and checking Task Manager for any apps using too much CPU. If it still heats up, you might need to get the fan or thermal paste checked.
Vansh Sharma crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 99
