Controllers for the Valve Index VR Headset released on June 28th 2019.
Thumbstick Cap Replacement for FJ06k-S(Valve Index Controller)?
Hi! First time here so sorry if I lack any proper etiquettes with the question..
With model reference: FJ06k-S in mind...
Problem: The thumbstick cap for my Valve Index Controller fell off and my cat chased and bit it to death so its unusable.
Question: Any recommendations on which caps I can use to fit over top and replace it?
Clarification: It doesn't have to be a whole switch, quite literally the plastic that fits over top of the stick that comes out of the switch. The flat thumb rest with a hollowed out tube underneath it that I can fit over the switch.
Attempted Solutions:
1. I've tried the xbox pro controllers cap, but they have 4 indents inside that make it unusable and no matter how hard I try to sand it, it wont. It's too tight.
2. Electrical tape bundle, but it looks ugly and stupid and the sensor doesn't work through it.
3. Make a fake cap out of plastic and just try to deal with it, but seems to be such a half butt solution.
4. Repair the actual cap itself, but it's in pieces and not worth the effort.
5. Search online for many caps but they're all too tight, or I haven't found the specific right size for.
6. Try to remove one from any other controllers, but they're all one piece, so it's not a viable option.
Hi there!
The best solution is to use original ones. They are very hard to find… I also cannot find them anywhere.
The only one I found is on Ebay: left side: https://www.ebay.com/itm/116381832183
Right side: https://www.ebay.com/itm/116381832598?_t...
Another option is to buy a broken donor Valve Index controller with another defect and get the thumbstick caps from there.
Hopefully you will get yourself one, so that you can fix your controller again! Please keep us posted!
Thanks for the help, the 40 dollars shipping made me realize I'd be better off trying to make my own out of one of the xbox pro pull offs and a drill as its a cheaper option.
I went looking for a broken controller but seems like the people that deconstruct them might have driven up the price enough. 30-70 dollars minimum for a broken controller.
These were solid options, thank you very much for the assistance and speedy responses.
Couldn't buy the ebay, it gave me a 40 dollar shipping price to Canada, RIP.
My pleasure! Ah.. then it’s not worth it I guess… I’m sorry! Hopefully you can fit the xbox caps. When it’s done, would you mind to share it here what you did to make it work if you have time? Thanks in advance!
I have resin 3d printed ones coated with Rubber like surface. You loose the proximity sensor, because you cannot find those online, but thats no Problem. If you are in the EU i can offer something 😉
Kisa Catharsis crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 78
crwdns2936753:030crwdne2936753:0 308
crwdns2942667:0crwdne2942667:0 919
